Hotpoint BF1680
  • #44453
    spimps
    Wondered what colour the inlet hose is when supplied.Worked on one (heater) and it had a red inlet hose inside the outer transparent cover which is supposed to indicate a leak and be bright red so slightlky confused .No leaks and no trace of previous leaks.
    #281017
    smartin
    Re: Hotpoint BF1680
    #281018
    spimps
    Re: Hotpoint BF1680
    No Comprehende ? Whilst checking the heater tube noticed the fill hose has an outer transparent cover with a normal looking fill hose encased inside,it says in the user manual that if the hose leaks it turns a bright red,the hose inside the outer transparent cover is redish so I looked for any sign of leaks current or past but can’t find any so am not sure what colour these hoses start of as.
    On suppliers lists thet retail at around £22 so wantyed to check first before ordering if not necessary. 😕
    #281019
    Re: Hotpoint BF1680
    If there is a water leak into the outer sleeve, the red inner tube will make the whole outer tube appear to be red.
    spimps
    Re: Hotpoint BF1680
    Thank you kind sir.
