Hotpoint BF71 error code F
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BF71 error code F
  • #17362
    bicky
    I hope someone can help! My son left the tap on and some water leaked into the dishwasher. It will not work. When the door is opened the cycle can be chosen and the time comes up as it should but then changes to F. Even with the door open the pump is continuously trying to work and the machine is putting a small amount of water in the bottom. Can anyone help? it was only a small amount of water and was working fine before. I am lost without it!! Thanks.
    #173955
    Re: Hotpoint BF71 error code F
    You may have a flooded base, first unplug the machine, then if you can pull it forwards and lean it back against a wall or cupboard, you may find water draining out from underneath, ( I should have warned you to get some towels handy). If it then works fine it must have been the water he allowed to overflow that caused the problem, if the fault does not go away or returns then you may have an internal leak that needs attention.
    Of course this assumes that whoever installed this integrated appliance did their job correctly, unfortunately the percentage is on the low side. 😥
