HI CAN ANYONE HELP. GOT A HOTPOINT BFI 620 dishwasher..original fault was not heating..send pcb board to be repaired, got board back and refitted but now when you set a program and shut door pump starts going then about 5 to 10 secs later it beeps and 1st neon flashing..looked up code says it water in base fault..base dry..changed float micro switch..still 1st neon flashes..continuity ok on motor, heater…tearing hair out..can anyone help…cheers :rolls: also continuity on orange wire from float micro switch to pcb board edge connector…..heeeellp
