Hotpoint BFI 620 dishwasher error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint BFI 620 dishwasher error code
  • #80274
    Latham63
    2nd led flashing. Locked,cant elliminate or change prog. Handbook suggests water load solenoid valve error? Inlet valve checks ok + salt container valve.
    Pcb?
    #412322
    Re: Hotpoint BFI 620 dishwasher error code
    have you checked contiuity from board to valve
    not sure this will cause this fault but its woth a look
    Latham63
    Thanks will check that. But surely the machine should start up & drain before valve activates?
    Or do these machines just lock up if there is a fault.Reset does nothing!
    #412324
    the honest truth i am not sure. i would have thought it would have pumped first then failed
    had a few of these boards where the power supply cap failed on the board but most of the time it would start, fill and fail when the motor or heater kicked in
    have you tried to reset programme as these tend to start where they left off unless you reset them ?
    Latham63
    Reset is normally press & hold start button for a few seconds.Or is there another procedure for these?
    The boards are about £85 retail for these.Did the board damage occur because of heater/motor earth fault?
    #412326
    no think its press and hold
    not heard of board being damaged by heater/motor earth faults at least not in houses with RCD’s fitted so things dont go bang
