I have a Hotpoint BFI62 that when put on the hottest setting it will not eject the tablet or heat up, it stops with the spray light flashing, hope you can help
Check cold water is actually on (those little blue tags can turn without opening the tap). If ok inlet valve may have failed or had wiring disturbed (you’ve been working in that area).
