Hotpoint BFI62 D/W
Viewing 15 posts - 1 through 15 (of 15 total)
  • #41414
    spanner51
    Hello
    Can anyone help please with this built in dishwasher
    Lights 2 and 4 were flashing which is a heater fault.
    Checked heater = OK
    Fills OK
    wash motor OK
    drain pump OK
    So fitted new module. Now it is completly dead. I cant even determine if it is in test mode, as there is no prog lights, no beeps, no nothing. The on/off neon is OK, so there is power getting to module. Any thoughts, or is the new module faulty? Thanks
    #270079
    Re: Hotpoint BFI62 D/W
    Have you checked the thermal cut outs ?. Recheck the board connections.
    Bryan
    #270080
    Why not pop the old module back in to see if it comes back to life. 😉
    #270081
    spanner51
    iadom wrote:Why not pop the old module back in to see if it comes back to life. 😉
    Thats what I did, and yes, it does come back to life, with the original fault still there
    #270082
    spanner51
    I have since found there may be 2 types of module.
    The one I fitted, C00143222, is a BIT100 F6 type, but there is also a BIT100 ‘G’ type. I am wondering if I fitted the correct one.
    #270083
    Jonah
    Good old Indes**** date codes !!
    Always check on Partfinder CD never trust your supplier.
    :rolls:
    #270084
    First of all, its a BFI62. Only one module listed on Partfinder. There is also a BFI620, this one does have two different modules.
    Module for BFI62 is listed as a C00096972.
    The I signifies integrated. 😉
    recall
    check the meg’s these m/c’s will go absolutely skitty even if slighty low, could be the htr limed up and cooked itself.
    #270086
    spanner51
    Went back to this d/w today to fit the module p/n C00096972.
    But it is different from the original. There should be a small socket on it to accept a small plug with 2 white wires, (not the ntc wires, they are black)
    but the socket is missing.
    Does any one know if there is a modification. Cheers
    #270087
    smartin
    the only way you are going to resolve this is to get the serial number and industrial code off of rating plate otherwise you are going to keep going round in circles.
    #270088
    spanner51
    you are right
    I did manage to repair the blown tracks on the old module. so customer is now happy. But I have wasted a lot of time on this one. Thanks to all who replied.
    smartin, what do you mean by the industrial code?
    #270089
    Also known as the commercial code, a five digit number.
    BFI62 should be 28837, BFI620 should be 30708 etc.
    spanner51
    Thanks for the info
    The actual numbers on the rating plate were
    BFI 62
    36703682
    LS12 EVO3
    412042774
    So the 36703682 must be the commercial code
    #270091
    According to the manuals the commercial code is made up as follows in this example.
    37 24455 0010…..although there may not be spaces between the numbers.
    First two digits 37 = the factory of origin
    Second five digits 24455 = the commercial code
    Last four digits……=not used.
    No combination of 36703682 comes up as a commercial code on Partfinder. 😕
    spanner51
    I hope someone can make use of the info in this thread, and not waste as much time as I did.
    The saving of £60 by not buying a partfinder disk was a false economy.
    Shame they don’t seem to be available any more.
    graham
