Hi, Been to one of these today that the lower spray arm had come off and caused the base to flood. I sorted the spray arm and drained the water from the base.
I then tried to run it through to check all was ok.
I put it on an eco wash and the machine filled as normal and started to wash but a min or so into the wash it pumped the water out and stopped with the 2nd light lit but not flashing.
Cheers,
Ray
