Hotpoint BFI620 broken… please help
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BFI620 broken… please help
  • #41893
    andybono
    My hotpoint BFI620(which after reading all the other posts i now realise is a lump of junk) is flashing lights
    from the left its the FIRST and THIRD green LEDs
    i have searched the other forum posts on this and it looks like im the only one with this led combination!
    anyone help??
    please
    #271670
    Re: Hotpoint BFI620 broken… please help
    Yep, its really an Indesit. 😥
    1+3 suggests blocked filters. you could try removing and cleaning all the filters etc that you can access from insde the tub. Then try it on a cycle with a dishwasher cleaner on the hottest setting. Fault is caused by failing to rinse the dishes properly before loading into machine.
    If it is really bad then a strip down is required to clean the internal hoses etc.
    Dishwasher Cleaner
    andybono
    thanks jim,
    cleared out the filters and it has spluttered into life!
    will get a cleaner and run that through it too
    next time i am definatly buying Bosch
    #271672
    Regardless of what make you buy it will always perform better if you take the time to rinse the plates off first.
    As we often say here, “its a dishwasher, not a waste disposal unit”. 😉
