hello
customer complaining that the dishes are comeing out dirty,
i had a quick look and found that the top spray arm is not turning .
it seems the top basket is not sitting far enough back so that the spray arm is not pushed in enough to the feed pipe.
the spray arm has two holes where it can take water from and the top one fits perfect when you fit it ,but then you can only get small dishes in the lower basket.
anybody got a cure? as i cant see anything stopping it from fitting.
