Hotpoint BFI620 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BFI620 Dishwasher
Viewing 1 post (of 1 total)
  • #35334
    MrT007 wrote:Hi I was wondering if you could help me.
    Whilst the above dishwasher was part way through it’s cycle, it has stopped functioning. The on/off button was still lit but there were no lights displayed on the menu/programme. Water was still in the bottom of the dishwasher. I have checked the filter and the pipes for blockages. When you switch the unit off then back on, the on/off button will illuminate but nothing on the menu/programming is lit. I would appreciate any help you could give me. Thank you.
    We are unable to offer technical advice by email or private message.
    The power lamp is switched directly by the on/off switch, all other functions are controlled by the computer board, therefore your most likely culprit is the computer board itself. Be advised that this can be a “cause and effect” fault – failure of another component can damage the computer. A full inspection of the machine would be in order before rushing out for a PCB.
    Power off if you plan to investigate this yourself.
