Re: Hotpoint BFI620 Door Seal Leak
Hi, no need for a new seal, you are right that it is only a splash guard, your problem is the powerball tablets, they are too strong (especially if you are in a soft water area), the excess detergent is causing the foam, when the correct dosage of detergent is used the machine will produce no foam, there are loads of posts on here about the problems of using these tablets
Run the machine on a few short cycles with nothing in it and the excess detergent will soon go, then switch to using basic tablets,
