Re: Hotpoint BFI620 – Error code
I’m afraid its drag it out of its hole time.
Lights 1+2 signify a drain time out error in most cases, it can be a software recognition error but that is not common.
The likeliest cause is a pump blockage, the filters on these Indesit machines are not the best and if you don’t rinse your dishes off before you put them in or allow small fragments of glass, bone, wood, chipped crockery etc to get through the filter it will stop the pump.
Mains plug out. towels all around and tilt it back or onto its left hand side looking from front. Access to the drain pump is from underneath after removing the base plate.
Click on the link below if you want professional assistance.
