Hotpoint BFI620 Heater Error?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BFI620 Heater Error?
Viewing 8 posts - 16 through 23 (of 23 total)
  • #256332
    jbeynon
    Re: Hotpoint BFI620 Heater Error?
    fess up to what? 😆
    think it was the o-ring not seated properly – reseated it, put the base back on….took the side off (:)) to watch it in a cycle and no leak.
    #256333
    See, you feel better for owning up, glad you sorted it. 8)
    wings3220
    New to the site and have to say you’ve all already saved me £99.98 on Hotpoints ridiculous call out! My heaters fine on my BFI620, so does that mean that my PCB is kaput? If so, can i buy new ones?
    Thanks again…
    #256335
    cockney steve
    ” Spares@ ” …see the bottom of the page 😀
    Super service (last time, under 20 hours, order to delivery)
    top-quality (no chinese knock-offs)
    Not the cheapest, but certainly the best value, imho.
    send ’em an email now 🙂
    #256336
    wings3220
    Thanks for that. Will order one and hope it works. Can’t believe that the problem with the lights isn’t in the owners handbook and Hotpoint Charge £100 (- 2p) for a call out! What a Rip off! Thanks for your advice. Just a quick one…is the PCB simple enough to replace for someone with a fair knowledge of white goods?
    #256337
    cockney steve
    Firstly, bear in mind that i’m NOT a qualified whitegoods engineer
    Second, have you eliminated any thermostat/thermistor/cutout/fusible link which may or may not be in circuit?
    Before jumping to the conclusion that it’s the PCB, you need to follow through the heater-circuit…..invariably, the wash set on the dial, corresponds with a specific temperature required to be” seen” -older machines had several different specific-temp thermoswitches,for this.
    I suspect yours may well have a thermistor which the PCB “reads” to check if the temp. required has been reached.
    Best wait-on for a more informed opinion, otherwise you’ll throw cash at it to diagnose by a process of elimination.
    Most PCB’s are “plug’n play” but some need a bit of soldering.
    not a difficult job if you have the basic skills 🙂
    #256338
    hotpnt
    hi wings, whats the problem your getting?, if its no heat then possibly will be the PCB, but if its erratic lights, how did you check that the heater is ok? as a lot of the problems on these are when the heater tests ok across terminals but has a short to earth which you will need to ‘megger’ to check
    if you are then sure its the PCB, yes, its very easy to fit, 10 – 15 mins should do you
    #256339
    MG ZS STE
    cockney steve wrote:Before jumping to the conclusion that it’s the PCB, you need to follow through the heater-circuit…..invariably, the wash set on the dial, corresponds with a specific temperature required to be” seen” -older machines had several different specific-temp thermoswitches,for this.
    Hi, I saw this thread whilst searching for the exact same issue as the OP. @cockney steve you may not be an engineer but you speak a lot of sense. I’ve put a multimeter on the heater cylinder and found I was getting between 25.8 and 27.8 ohms depending on how steady I could keep my hands. I turned the juice on and flicked the multimeter to volts AC and expected to see 230 volts but nothing. Well 1 volt but that quickly trickled away to zero. I don’t want to assume that this is the board but, is it? I’ve taken it off and examined all the soldered joints with my jewellers loupe and can’t see any signs of burning. So I’ll throw it out there. Should I be following through the heater circuit before condemning the board and how would I do that?
