Hotpoint BFI620 heater fault Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint BFI620 heater fault This topic has 2 replies, 3 voices, and was last updated 15 years, 3 months ago by Johnnyboy. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts December 20, 2010 at 4:50 pm #59694 JohnnyboyParticipant Hi guys this one is 2+4 heater fault, the legs are broken (cemented in) and cant get the machine out, is there a way of checking heater continunity from the PCB? Im hoping its the PCB personally. Cheers Johnnyboy December 20, 2010 at 5:48 pm #339270 iadomModerator Re: Hotpoint BFI620 heater fault You would have to fill it to close the pressure switch then test between F2 on the PCB heater relay connection and the door switch. Or between F2 and one or other side of the detergent solenoid. Jim. December 20, 2010 at 5:58 pm #339271 timdowningParticipant Re: Hotpoint BFI620 heater fault If you can electrically disconnect the machine. Reach through the front right hand inspection panel and unplug the heater. Make a fly lead and test with that. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
