Hotpoint BFI620 intergrated dishwasher heater fault?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint BFI620 intergrated dishwasher heater fault?
  • #28182
    whiskeyjack6058
    Went to one of these evil things the other day. After about 2 mins washing at the begining of the cycle, it pumps out then LED’s 2 & 4 begin to flash. I understand this error code indicates a heater fault. I have tested the heater for resistance, and used a Mega to check for for earth leakage and all checks fine. Perhaps this could be the module that is faulty??? Considering that the dishwasher has allready had a new heater fitted by hotpoint and numerous other repairs, my thoughts point towards the PCB. Any ideas?
    Thank you
    Regards
    Rob.
    #217268
    smartin
    Re: Hotpoint BFI620 intergrated dishwasher heater fault?
    is it a chinese d/w if it is some have cut out stat underneath on the left hand side rear or if not could be group of stats underneath between sump and salt chamber hope this helps smartin
    #217269
    Hotpoint don’t use Chinese produced machines ( not yet anyway 😥 ) although it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit, no cut outs AFAIK on these so module is a possibility, not the cheap module on these though, around £41 ex vat list price.
    senseib
    Often on hotpoint d/w pcb’s there is a dry joint at the heater connection.
    Just resolder and this cures the problem. hope this helps.
    brian.
