Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint BFI620 Won’t programme or start.
- This topic has 5 replies, 2 voices, and was last updated 19 years, 2 months ago by
bantam.
January 29, 2007 at 8:58 pm #24601
bantam
ParticipantI have a BFI620. The left LED is flashing as normal, but when I press the “P” button nothing happens. I have tried mains disconnect and I have pulled the unit out and tipped as an earlier response mention flood protection, but I don’t think the LED is flashing fast enough.The dishwasher is still pulled out at the moment so a quick response would be appreciated. I am an ex sparky so tackling a fault does not daunt me, but I could really do with some advice.
Cheers
Andy.
January 29, 2007 at 11:02 pm #202619iadom
ModeratorRe: Hotpoint BFI620 Won’t programme or start.
Have you tried pressing and holding the P button, sad to say the Indesit made dishwashers do have rather suspect electronics though.
Repairing most modern Indesit machines daunt many of those who have been in the trade for years. 😥
1st led flashing is supposed to signify water in the base.
January 29, 2007 at 11:13 pm #202620bantam
ParticipantRe: Hotpoint BFI620 Won’t programme or start.
Yes tried that. When the machine is first switched on it beeps then the LED starts flashing which all seem ok, then — nothing.
January 29, 2007 at 11:22 pm #202621iadom
Once you have isolated from mains you could try tipping it over fully onto its left hand side, looking from the front, place a few good sized towels underneath it first. You should be able to remove the base and at least do a visual inspection, check for signs of water on the base, sticking float switch or float microswitch.
January 30, 2007 at 11:33 am #202622bantam
Thanks Jim,
In the end I opened up the door and looked at the controller inside. The unit had moved slightly so the rocking programme switch was not making contact with the button on the pcb. I have repositioned it and now you get that positive clicking sound when the P button is pressed. All is OK.
Cheers
Andy.
January 30, 2007 at 4:13 pm #202623iadom
They do need treating with kid gloves, very easy to break the fixings on the control buttons.
