Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint BFi670 configure
- This topic has 8 replies, 4 voices, and was last updated 17 years, 5 months ago by
bradley.
November 7, 2008 at 4:26 pm #40843
bradley
Participanthelp! having problems configuring hotpoint bfi670 .after fitting module.Despite following instuction 2 do test cycle .the hotpoint did 1 test cycle now wont work atall.only the salt and rinse aid light flashes now and wont reset.any ideas?
November 7, 2008 at 9:01 pm #267745johnnyj
ParticipantRe: hotpoint BFi670 configure
Did you swap over the edge conector on the side of the timer, i’ve seen a few forget to do this and you will get a the test programe but will do nothing else, also when you fit the board to get it out of the test programe when the fill starts you cancel programe and it should be set for normal operation , hope this helps JJ
November 10, 2008 at 1:05 pm #267746bradley
Participantjohnnyj wrote:Did you swap over the edge conector on the side of the timer, i’ve seen a few forget to do this and you will get a the test programe but will do nothing else, also when you fit the board to get it out of the test programe when the fill starts you cancel programe and it should be set for normal operation , hope this helps JJ
this is a dishwasher and has no edge connector on board
November 10, 2008 at 1:21 pm #267747johnnyj
I know it is a dishwasher and it should have a small edged connector sometimse with a resistor attached, it is there to determine if it is free standing or built inn if it is not there you wont get it out off the test programe.
November 10, 2008 at 1:35 pm #267748helo_75
Participantbradley wrote:
johnnyj wrote:
Did you swap over the edge conector on the side of the timer, i’ve seen a few forget to do this and you will get a the test programe but will do nothing else, also when you fit the board to get it out of the test programe when the fill starts you cancel programe and it should be set for normal operation , hope this helps JJthis is a dishwasher and has no edge connector on board
pmsl, i wouldnt challenge a hotpoint engineer as to whether he knows if its a dishwasher or nothowever, he’s spot on
November 10, 2008 at 1:59 pm #267749bradley
i cannot c this edge connector.its a built in one.there r some wires that go 2 a thermister which hangs on the front of inner door.
November 10, 2008 at 2:09 pm #267750helo_75
Participantthere was some post about a memory effect!
have you tried refitting the original pcb, resetting the program, then putting the new one back in?
November 10, 2008 at 2:10 pm #267751eastlmark
ModeratorRe: hotpoint BFi670 configure
Not only a diswasher but a built in one! Never have guessed really 😆 Bradley, I think they are trying to say there is an edge connector missing on the board you have just fitted that needs swopping from the old board to the new one.
November 18, 2008 at 3:19 pm #267752bradley
sorry boys .found out with electruepart/connections sent us the wrong board.after doing a part no enquiry!
