Hotpoint BFI680 Fault Code 5&7
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BFI680 Fault Code 5&7
  • #62033
    Hello
    My dishwasher is displaying the above error codes 🙁 which I believe (according to my google research!) is something to do with the heater……my question is, how do we fix it without expensive call out charges!!!?
    Many thanks
    Claire Caple
    #348451
    Re: Hotpoint BFI680 Fault Code 5&7
    If you mean you have lights 5+7 flashing then the fault is in the heater circuit.
    It could be heating element, connections, module, relay or pressure switch.
    You need to unplug and drag the machine out and then test the heating element for resistance and continuity with a megger or suitable multimeter.
    If the heater is OK then its 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain the control PCB is faulty.
    #348452
    Oh dear, as I have no idea what a megger or suitable multimeter is, I guess I best call someone out!?
    #348453
    BTW, thank you very much for your help.
    #348454
    The heating element is around £38 +vat, the control module about £60 + vat and there are two different modules.
    Bottom line is that this is not a Hotpoint but a rebadged, low end Indesit appliance. 😥
