Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint BFI680 Hose clips
- This topic has 21 replies, 9 voices, and was last updated 14 years, 10 months ago by
maltheviking.
May 16, 2011 at 4:00 pm #62825
maltheviking
ParticipantCan anyone help with the part no’s of the hose clips required when changing the wash pump on these Hotpoint Indeshit dishwashers. Need to be narrow jubilee types
May 16, 2011 at 4:14 pm #351425iadom
ModeratorRe: Hotpoint BFI680 Hose clips
The official ones are several pounds each, others have mentioned on the forums that their local Vauxhall dealer stocks this type of clip at a fraction of the price.
Unfortunately I have drawn a blank at my local Vauxhall dealer. 😥
One of the clips is a C00211358.
May 16, 2011 at 4:34 pm #351426maltheviking
ParticipantRe: Hotpoint BFI680 Hose clips
Yeh I remember the post from a couple of years back, there have been the odd posting recently , I thought someone might have sussed some clips out from other makes. The last pump I did I used Jubilee’s, not the best but got it going, just like to get some smaller ones.
May 16, 2011 at 9:35 pm #351427ray.t
Hi, I had this problem the other week, went to all my local motor factors and none of them had anything like it.
My local Halfords had a range of thin jubilee clips, worked a treat.May 16, 2011 at 9:45 pm #351428iadom
Hmm, last time I looked in Halfords they had no thin jubilee clips, may have another look.
I don’t suppose you have a part/stock number for them?
May 17, 2011 at 6:18 am #351429ray.t
I do yes,
18-25mm HFX382 item code 971507
25-35 and 27-40mm HFX384 item code 971523
They were on the rack with all the car fuses scotch locks and that sort of stuff.
I used them for a Kenwood dishwasher so not sure what size you would need for the hotpoint. They are 9mm wide
RayMay 17, 2011 at 7:25 am #351430Criscold
Try Merlin Motor Sports – 9mm Wide made by Norma
http://www.merlinmotorsport.co.uk/AIR-D … index.htmlMay 17, 2011 at 7:44 am #351431maltheviking
Plenty of suppliers of 9mm wide clips available, this one seems to be quite reasonable in their pricing
http://www.anyclamp.com/mikalor/single/ … ually.htmlMay 17, 2011 at 9:18 am #351432iadom
The one I listed as a Hotpoint part above is a 5mm wide clip.
1801927/C00211358.
Surely 9mm ones are bog standard jubilee clips?
May 17, 2011 at 11:25 am #351433Martin
iadom wrote:Surely 9mm ones are bog standard jubilee clips?
I agree. The size of clip needed should be 5mm. And there’s not too many that do that size unless you look out for stainless ones and then their extendable diameter (OD) is a bit limited.
May 17, 2011 at 11:42 am #351434Criscold
Bog Standard clips are 12mm – I have always used these on the whirlpool DW pumps and sump hose – perfect fit but never had to fit one onto a Hotpoint pump
May 17, 2011 at 4:34 pm #351435maltheviking
Martins right, 5mm width is more suitable, I have the odd 5mm type made by Oetiker, finding a supplier of these is the problem. Oetiker make the crimp on bands which are the factory fitted type, anyone using these?
May 17, 2011 at 6:05 pm #351436iadom
By far the largest number of jubilee clips I have are 9mm, the only ones that are 12mm are the very big ones for Hotpoint WMA sump hoses and the like.
The ‘average’, most common jubilee clip is a 9mm one which is a tad to big for the dishwasher hoses. 😥
The ones supplied by Hotpoint/Indesit are the Oetiker 5mm, 28-39 ones. They should be gold plated at the price they charge for them.
I have trawled the WWW to try and find someone who would supply these in sensible quantities to no avail. :rolls:
May 17, 2011 at 6:49 pm #351437maltheviking
iadom wrote:
I have trawled the WWW to try and find someone who would supply these in sensible quantities to no avail. :rolls:Jim.So have I Jim, so have I 🙁
May 17, 2011 at 9:15 pm #351438deltra
there is some clips that fit,they are whirlpool ones,i think they might be available in ukw shop. (not cheap tho.)
