Hotpoint BFV62
  • #14834
    spark
    Hotpoint BFV 62 D/Washer
    Discharge pump operates on all cycles….but no fill.
    Phase to solenoid valve, no neutral.. [neutral wire goes to module]
    No burnt connections on module or cables.
    All suggestions welcome.
    Thanks, Spark
    #160975
    Re: Hotpoint BFV62
    Are you getting any error code warnings, lights flashing etc, this machine has the 100 bit control module that should generate error codes.
    #160976
    spark
    Re: Hotpoint BFV62
    Yes,light on left flashing constantly.
    Tks.spark
    #160977
    Dave_Conway
    Re: Hotpoint BFV62
    dishwasher fault codes with bit 100 pcb(written on serial no)
    led1=overflow water in base
    led2=inlet valve
    led3=hermister
    led4=timeout heating
    1+2timeout draining
    2+3timeout filling
    1+3filters blocked
    1+4software error
    2+4heater
    3+4timer hardware
    #160978
    spark
    Re: Hotpoint BFV62
    Thanks Dave.
    Led 1 is on but no water in base.
    The mystery deepens.
    Are there any other possibilities?
    Regards spark
    #160979
    spark
    Re: Hotpoint BFV62
    Found the prob.no water in chamber but float stuck.
    Thanks to Dave and iadom, wouldn’t have found it without your help.
    One of the old boys [cam switch era] so the electronics still give me probs.
    Many thanks,spark 😀
