Hotpoint BFV620
  • #44712
    ineedhelpplease
    Hi my mums diswasher has devloped a fault it seems to wash ok but not dry.
    at the end of the cycle the 4th led is lit (last one in in the bank of 4)
    I have checked the element with a test meter and it has a circuit and not going to earth.
    Cheers for any help
    #282026
    Re: Hotpoint BFV620
    ineedhelpplease wrote:I have checked the element with a test meter and it has a circuit and not going to earth.
    I would check that heater again if I were you. 😉
    #282027
    ineedhelpplease
    Re: Hotpoint BFV620
    cheers for your advice but the heater is testing fine around 25ohms if i remember correctly
    #282028
    Re: Hotpoint BFV620
    If the heater is Ok then it could well be the control PCB, both the heating elements and the PCB’s are very prone to failure on Indesit dishwashers.
    The PCB is around £50 though so you need to be certain the heater is fine.
