hotpoint bhwd 129 wont spin
  • #79123
    slyp98
    Hi guys , this machine wont start a spin , it will start the drain pump ok but just sits lights on nothing doing , i tried a wash program it will take water in but then just sits there anyone
    #408026
    Re: hotpoint bhwd 129 wont spin
    So what have you tested or checked. ❓ ❓ ❓
    #408027
    slyp98
    Nothing didn’t have time looking for any general faults , is it usual hotpoint board fault?
    #408028
    slyp98 wrote:Nothing didn’t have time looking for any general faults.
    Seriously, you haven’t even looked at or tested the motor or the motor plug connections, have you not even checked the belt? :eeek: 🙁
    That means a return visit which will take up even more time. :con:
    #408029
    If you’re short of time and don’t wish to open her up, simply place one of these on the top and stand well back….. 😉
    #408030
    slyp98
    No lads its in my sisters house 100 miles away i got her to do a quick check over the phone in not drivin up to find the shaggin belt is off, in lookin for an idea of what i need to bring maybe a pressure sw or a solenoid ya know the parts someone has used to repair this kind of problem b4 but it looks like nobody has come across one of these
    #408031
    slyp98 wrote: it looks like nobody has come across one of these
    Seen loads of them in various guises, it’s just an Indesit badged as Hotpoint, three phase motor job.
    Motor wiring connections very poor, motors do fail along with modules. Most faults will throw up an error code.
    The only way you will be able to go with all the possible parts required is if they are fitted inside a cabinet. 😉
    #408032
    slyp98
    no 220v at the motor , press sw checks ok wiring ok to the board drain pump kicks in for 3seconds and then nowt, no lights, no error code looks like fried board i don’t see anything obvious but its smelling burnt
