hotpoint BHWD129 Home › Forums › Trade Technical & Spare Parts Forums › hotpoint BHWD129 This topic has 1 reply, 2 voices, and was last updated 4 years, 7 months ago by delta01. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts August 17, 2021 at 9:46 am #99947 delta01Participant hi i unblocked this machine and it now empties fine but wont fill when you select a program the pump runs for about 90seconds then stops without filling , i suspect the module, any suggestions appreciated thanks john August 17, 2021 at 7:07 pm #478599 electrofixModerator try this open door and put around 2 litres or more water in the drum close the door and select a pump out only programme and let it go till it stops hopefully it will re calibrate the pressure sw so it know where empty is also any fault codes coming up ? dave Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
