Hi all I don’t do Hotpoint, but a friend has a problem, when I looked at it the machine had no water in it and had been switched off at the mains. I turned it on and the top four lights on the right came on, don’t know if this is normal or a fault code. I tried to set a drain program and it started to fill, then drained for a few seconds then started to tumble, no instruction book, unable to cancel the program, it also wont turn off via the on off button, suspecting the front pcb, any help would be appreciated, thanks Cliff
