hotpoint boots
  • #64577
    wilf
    Anyone know the difference between 1605550 and 1605335 there listed seperately for wf and wt but I cant see any difference. For the second time I’v just fitted a 1605550 (gsk9197) to a wt960 where a 1605335 is listed seems a perfect fit. Not had any problems.
    wilf
    #357447
    Re: hotpoint boots
    Jim’s your man on the subject but my guess is one fits a welded drum the other a split drum maybe?
    #357448
    timdowning
    Re: hotpoint boots
    I may be wrong, but on the higher spin models aren’t there drain holes all the way round the door seal rather than just at the bottom??
    I had a FEW12 that had a welded tub with a WMA front panel. Tried a WF seal and WMA but neither fitted. Customer in the end was happy with me cleaning and refiting. FEW I thought. That was a crap pun wasn’t it.
    #357449
    Re: hotpoint boots
    Hmm, not had cause to order or use a 1605335 yet. Fit loads of 1605550 ones though.
    May order one just to compare them. 🙂
    helo_75
    Re: hotpoint boots
    different drums, different sizes depending on commercial codes
    welcome to our world
    #357451
    wilf
    Re: hotpoint boots
    I checked the boots carefully and could not see any difference at all and as I said fitted perfectly.
    wilf
    #357452
    washtronics
    Re: hotpoint boots
    i used to work for hotpoint and never fitted the 1605335, always fitted 1605550 fits all wf and wt machines but not wma
    #357453
    Re: hotpoint boots
    Just got hold of a 1605335 this afternoon.
    It does say 7kg on the inside of the small locating flap and on the outer edge it has EPDM which the 1605550 doesn’t but if I line it up against a 1605550 I can see no difference at all. :con:
