Hotpoint DWF31S/29
SGSHPE6GB FD8204
This dishwasher had a hole in the heater housing so i fitted new heater. Then i discovered it was not heating as the leg on the heater relay had burnt out so i sent it off to EMW for repair. When i fitted it, the problem is when you select the quick wash it shows 96 minutes in the display. Customer says this should be 30 which sounds right. This machine has INTENSIVE, NORMAL, ECO, QUICK and PREWASH when selected the first three show 2 hours the quick 96mins and prewash about 25 i think. The quick wash does start heating the water straight away. Whats going on.
Configuration?
Subs
