Evening All,
I have recently purchased a house for use as a rental property fitted with the above single oven, however due to poor installation of the oven or its housing unit the lower right hand side of the door has been catching on the filler panel under the oven (now rectified), this has caused the mounting bracket to detatch from the outer glass panel, having looked around it appears the door glass is no longer available,I seem to remember someone having a similar problem before, could anyone please recommend a suitable adhesive or other solution to re-bond the glass to the bracket.
thanks in advance.
