Hotpoint BS63E Oven
  • #29582
    goosegreen
    Calling tomorrow to the above and customer told me he is getting the fault code E or F8 showing on the display. Checked known fault codes but nothing listed for Hotpoint cookers, Would any one have a clue as to what Fault 8 relates to?.
    Cheers
    Goose
    #223716
    robbra
    Re: Hotpoint BS63E Oven
    Hi Goose,
    Had “E” several times and it has always been an overheat situation after grilling and when allowed to cool works ok. Shouldn’t happen but does.
    HTH
    Rob
    #223717
    goosegreen
    Thanks Rob, Thats something to go with will check cooling fan and ventilation.
    goose
    #223718
    goosegreen
    Called back today and customer told me the fault appeared when he used the Multi cook function for the first time, Oven worked after it had cooled down, so suggested due to a possible installation problem it my be wise to use the fan oven setting rather than the multi cook as apparently it uses all the elements together.
    Goose
