We have a Hotpoint BU72 double oven. It tripped the main breaker, after which the lights still worked but the bottom oven didn’t get hot. The Forum pointed me to the fan element – I confirmed it was open circuit and had a hole in it, ordered a spare from here (very fast delivery) and fitted it.
I’ve just edited this post to remove my query about why the fan wasn’t working when I tested the oven – which was because I had the door open!
Re: Hotpoint BU72 oven fan / element (info only: problem sor
Hello Forum,
I see two people have had a problem the Hotpoint BU72 bottom oven blowing out the RCD. The light and fan still work but there is not heat. Any advice please as to what bit needs replacing and a part number/description. Many thanks.
Roger G
