Hotpoint BW61P Washer/dryer help?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint BW61P Washer/dryer help?
Viewing 1 post (of 1 total)
  • #22757
    I’ve got one of these built-in machines to replaced the door boot (1601955). I wonder if the front panel can be removed to access it without getting the machine out?
    The builders fitted the machine in this tiny utility room then cemented the ceramic floor tiles right up to the adjusting feet. The feet will not budge so getting it out is not an option. I need to order a new seal and return to fit it but won’t bother if the front panel cannot be removed in situ?
    Conventional Hotpoints at least require taking the lid off to access the timer knob before the control panel front can be removed. This beast looks every bit the same as far as I can see. The knobs will have to be removed first I should think?
    HELP !!!! 😕
