It doesn’t go past the wash cycle. The only way is to manually move it on, then all other cycles work ie spin, drain etc… It just seems to stick on the wash cycle.
Have checked filter, all clear.
HELP.
If you are unable to test electrical components then you should leave it to someone who can for your own safety if nothing else. You should not be attempting to repair any appliance without such knowledge.
