HOTPOINT BWD129 ERROR CODE
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HOTPOINT BWD129 ERROR CODE
  • #23650
    RIGGER
    HELLO
    MY 13MONTH OLD HOTPOINT BWD129 HAS STOPPED DRYING AND HAS THE FOLLOWING ERROR CODE
    DOOR LOCKED LED FLASHING RAPIDLY
    LED 3 AND LED 4 QUICK WASH AND 1200/600 SPIN FLASH ON AND OFF TOGETHER
    I NOTICED SOMEBODY ELSE HAS HAD THE SAME PROBLEM AND THE SUGGESTION WAS THAT IT MIGHT BE THE NCT, WHAT IS THIS AND HOW MUCH WOULD THE PART COST?, DID IT FIX THE FAULT?, OR WOULD IT JUST BE CHEAPER TO CALL HOTPOINT OUT, PAY THE £90 AND CLAIM THE FREE PARTS
    HELP PLEASE,
    #198929
    Re: HOTPOINT BWD129 ERROR CODE
    Sad fact is that this machine is virtually 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit, thats means it has very ticklish, over complicated electronics that can be a real pain to fault find and cure.
    The NTC is the water temp controller, the component may be faulty but that is not common, poor connections, damage to the PCB etc can also give rise to this error and are far more common.
    You could easily find a loose or broken connection, you may not find anything obvious though. The Indesit engineers have software that is unavailable to the trade allowing them to do much more in depth diagnostics.
    Your call really, if it is just a loose connection, a local engineer would certainly be much cheaper, if it turns out to be the PCB then the manufacturers g/tee is the way to go.
    Please be sure to remove the mains plug before you open it up.
