Re: Hotpoint bwd129 led flashing
Neons 2 & 4 equate to fault F05, pressure switch stuck on full on this Indesit machine. It could be blocked pump or filter, faulty pressure switch, blocked pressure hose etc. You can check the filter to the pump yourself, it is down at the bottom right, get a few towels handy.
That machine will be covered by the five year parts guarantee however their labour charge is almost £90.00
Be sure to remove the plug if you open it up.
