Hotpoint BWD129 Washer/Dryer Stops on Programme G
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint BWD129 Washer/Dryer Stops on Programme G
  • #27301
    ibur
    We have a BWD129 Washer Dryer that stops on RINSE when using programme “G”. It will not recommence until you press the start button. There are NO error indicators other than the RINSE LED flashing.
    We had an engineer out to look at this and said it needed replacing. We’ve had the replacement and this has the same problem.
    Does anybody know what this is or experiencing the same problem. It does however work completely on Programme “D”. We’re baffled and at the moment so are Hotpoint.
    #213456
    timdowning
    Re: Hotpoint BWD129 Washer/Dryer Stops on Programme G
    worth checking that the drain hose isn’t to low. the g programme may have a higher fill level than the d programme. (the drain hose being to low or to far down the house drain pipe causes syphoning of the water.)
    #213457
    ibur
    timdowning,
    Thanks for the info; The kitchen installers did apparently fit the pipe too low in the first case (engineer didn’t notice this), but an engineer has fitted the second. I’ll strip it out and have a look
    Again thanks for the prompt reply.
    #213458
    hotpnt
    make sure the outlet rises up high before it enters the sink outlet, where did they get the 1st engineer from who replaced the machine???
