Hotpoint BWM12
  • #31784
    philes
    Hi, problem with a hotpoint BWM12.
    Fills a little, turns drum, then pumps right out, and the dial clicks around.
    Light flashes 3 to 4 times i think.
    If the pump is drained out completely via the filter in the front, the machine then works for a couple of times but then reverts back to the above fault, its had a new drain pump not long ago.
    Any idea what could be the problem ?
    I was thinking its might be the pressure switch, but it seem to be clicking in and out ok.
    HELP !!!
    Phill
    #232504
    Re: Hotpoint BWM12
    So, is it three or is it four, makes a difference. 😉
    philes
    Re: Hotpoint BWM12
    sorry, cant remember , its at my flat and im not there at the moment, got a call about it earlier, whats it if its 3 flashes and whats it if its 4 flashes ?
    #232506
    Re: Hotpoint BWM12
    Note that these flashing lights are only a pointer to the possible area at fault, the electronics on these Indesit machines are notoriously unreliable.
    3 flashes suggests an NTC ( temperature control device ) or its related circuits are faulty.
    4 flashes points to a pressure switch fault.
