Hotpoint bwm129 built in door seal
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint bwm129 built in door seal
  • #76550
    allan
    Hi have been out to above machine Hotpoint bwm129 to fit new door seal, the original seal is held in place by a thick wire and hook, does this require a special tool to replace ? Also there seems to be two seals for this model the other uses a sprung ring, could this be fitted to the other type of seal instead of the hook type or could I change the seal and clamp?
    Thanks Allan
    #398751
    Andy jones
    Re: Hotpoint bwm129 built in door seal
    There not interchangeable mate. No special tool and they are a bit of a pig to fit. Just put clamp around seal link together and then lever over the seal.
    #398752
    johnnyj
    There is a tool a modified pair of pliers i dont know if they are still available even with them its stil a fiddly job.
    #398753
    Simon46
    Cable tie and pliers.
    post374746.html?hilit=pliers#p374746
    Qualtex do a set of 45 degree QUAMIS205 but I have borrowed a set from b@ q before and returned undamaged 😯 😯
    #398754
    allan
    Thanks for all your input, look like its going to be a fun job! Will savour every minute 🙁
