Hotpoint BWM129 Flashing Delay and Door Locked Lights
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint BWM129 Flashing Delay and Door Locked Lights
  • #82596
    mmeakin
    The lights flash continously.
    This first happened a couple of days ago but the problem went away but it as now returned and appears to be permanent.
    The wash works, there are no blockages in the filter and the machine drains quickly, the drum is rotating and changing direction during the pump out cycle, it seems to try to accelerate but then stops and the lights start to flash.
    #420362
    Re: Hotpoint BWM129 Flashing Delay and Door Locked Lights
    Those lights are supposed to signify fault code F08. If you do a search of this forum and enter’ 8 flashes, Indesit’ you will get some idea of your problem. 🙁
