Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint BWM129 flashing light – SPIN and QUICK WASH
- This topic has 4 replies, 2 voices, and was last updated 13 years, 5 months ago by
mouters.
November 18, 2012 at 12:05 pm #72588
mouters
ParticipantHi,
RE: Hotpoint BWM129
The drum won’t turn and has flashing lights – SPIN and QUICK WASH.
I’m able to start a wash (but no turning/spinning) before lights start to flash – switch off the machine off – it will then drain (its pumping water out). But the main drum won’t turn/spin on wash cycle.
The belt appears to be ok and i can manually spin the drum without any thing restricting it or noises.
Can someone tell me what the problem might be?
Thanks for your time 🙂
November 18, 2012 at 12:26 pm #384996iadom
ModeratorRe: Hotpoint BWM129 flashing light – SPIN and QUICK WASH
Can you give us the flashing lights by position number from top to bottom or left to right.
Sent from my iPad using Tapatalk HDNovember 18, 2012 at 1:22 pm #384997mouters
ParticipantRe: Hotpoint BWM129 flashing light – SPIN and QUICK WASH
Hopefully you can get to this link
http://sdrv.ms/SErmFQbut if not then on the left side we have (listed top to bottom)
– Prewash
– Wash
– Rise
– Spin – *FLASHING*on the right hand side we have (again top to bottom)
– Delay Start
– Super Wash
– Quick Wash – *FLASHING*
– Rinse HoldThanks
November 18, 2012 at 1:33 pm #384998iadom
The error codes on this Indesit :rolls: made appliance are given using the right hand buttons flashing, erro codes do not use the left hand lights.
If you have light 3 on the right flashing then it is supposed to signify a motor fault.
It could be anything, faulty motor, main pcb, poor wiring connections etc,
Indesit electronics are known to be some of the least reliable on the market so anything is possible.
If you do intend to investigate further then remove the mains plug and leave it for at least 15 minutes before putting your hands inside, it has a 3 phase motor and the pcb can pack a hefty charge.
November 18, 2012 at 1:43 pm #384999mouters
I presume you’re saying Indesit because the bwm129 is rebrand as hotpoint. I’ve already opened the machine and wires appear to be good.
How would I determine if it’s the motor or the pcb?
