I have been to look at this machine today to find the heater turret has come awat from the outer tub. I took the heater out and the turret is still in the heater but cannot find the fixing screw. Is there an easy way of refitting a new one other than taking the drum apart. Also has any one got a part no for the turret and fixing screw and there must be a seal as well. Any help would be appreciatre
Andy
hi, think this is the metal tank so you cannot take it apart, you should be able to hold the bollard in place through the sump outlet hole, real finger scraping job though, think the screw is m6 can usually find something in the bottom of toolbox to fit it, the washer is a fibre type
