Re: Hotpoint BWM129 mysterious water fill
Its either a faulty inlet valve or dodgy outlet pipe plumbing.
If you find water in the machine in the morning before the sink has been used then one of the inlet valves is faulty.
Simple test, turn off the hot (red) tap to the machine overnight and then check in the morning, if there is water in the drum and you turned the hot off then the cold valve is faulty if not then the hot valve is faulty.
If your outlet pipe is connected directly to the undersink plumbing then you need to make sure that at some point it is routed above the lowest level of the sink, if not the waste water from the sink can drain into the washer.
