Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint C361EW electric cooker
- This topic has 3 replies, 3 voices, and was last updated 16 years, 3 months ago by
ddirect.
December 31, 2009 at 9:09 am #51281
ddirect
Participantopening the main oven door when in use causes electric to trip, switch trip back on oven works as normal,this fault is intermittent and only happens when opening oven door , opening the oven door operates microswitch to cut power to fan and element, have done insulation test on individual components apart from the main oven switch and thermostat situated behind the facia panel, i am pressuming the fault lies within one of these two components, but which one? has anyone else had this problem, is it best to replace both components or am i totally wrong and barking up the wrong tree? any help appreciated.
cheers darrenJanuary 1, 2010 at 1:19 pm #307455Phidom
ParticipantRe: hotpoint C361EW electric cooker
I assume it’s the RCD that trips? You could try removing the switch from the panel to isolate its metal parts from earth and see if it still trips. You can do the same with the thermostat but you would have to also isolate the capillary and probe. Have you ruled out the microswitch? I know they are plastic but some have metal rivets which may touch earthed metalwork.
January 1, 2010 at 9:34 pm #307456burns
Had a similar situation with a Neff double oven, intermittently tripped out the RCD, insulation tests showed nothing. It would heat up to the set temp and trip. reset and it was ok, if you then raised the temp setting it would be fine until the stat opened again.
Eventually tracked it to a faulty element????
Seemed hard to understand why it would throw the rcd when the circuit was broken. Could only put it down to an out of balance on the RCD circuit. New element and its been fine ever since.
Definately try a new element, easy to fit, cheap to buy. Probably the quickest way to test it out and its not the end of the world if its not that. (which I strongly suspect it will be) 😉January 2, 2010 at 6:55 pm #307457ddirect
thanks chaps for info, a bit more food for thought, will post back to let you now results,not going back for a while as they going on hols.
