Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint CDN7000P (UK) Tumble Dryer intermittently spinning
- This topic has 27 replies, 2 voices, and was last updated 2 years, 5 months ago by
The Equalizer.
October 13, 2023 at 5:17 pm #102314
The Equalizer
ParticipantHey Y’all
My old Hotpoint CDN7000P(UK)
Serial 505126563
Thanks to you kind folk on this forum, I have replaced the Belt in the last year & the Pulley & Gasket around the front of the drum.Anyhow, today it decided to stop spinning. Its heating ok, and I noticed that with no load or very little, it will spin but literally only with 5 pairs of socks, that’s about it anymore, and it stops spinning, but makes a humming sound.
So the belt is intact, no burning rubber smell.
The pump is ok I think, I can hear it gurgling away.So I just wondered if you could once again point me in the right direction of what might be going on, or where to look?
Thanks once again
Simon
October 13, 2023 at 5:22 pm #488298The Equalizer
ParticipantOne more thing.
Even with nothing in the dryer as the drum turns there is a slight thudding, as you would hear maybe if there was a full load and the load is falling side to side as the drum turns, but there is no load!
October 13, 2023 at 8:54 pm #488299The Equalizer
ParticipantSorry Can a moderator please amend the Topic title it should read [h=2]Hotpoint CDN7000P (UK) Tumble Dryer intermittently spinning[/h]
I have a sticky no.7 key, sometimes it doesn’t work.Thanks
Simon
October 13, 2023 at 9:38 pm #488300electrofix
Moderatorcommon fault for no drum turn is the capacitor
it normally starts with light loads but need a push to get a heavier load moving
October 15, 2023 at 10:38 am #488301The Equalizer
ParticipantThanks Dave
Its stopped turning altogether at the mo, it is making a sort of buzzing crackling noise.
Still possibly capacitor?If so, where is the capacitor situated, and is it replaceable?
SimonOctober 15, 2023 at 10:40 am #488302The Equalizer
ParticipantYeah, its started moving now.
Very puzzling?
October 15, 2023 at 11:06 am #488303electrofix
Moderatorcap is replaceable and sited next to the motor
October 15, 2023 at 11:06 am #488304The Equalizer
ParticipantI’ll head over to the online UKW shop
See if they have a capacitor.Thanks for your advice Dave
October 15, 2023 at 12:14 pm #488305electrofix
Moderatorthere are different values depending on motor fitted
you can either let us have the complete set of numbers off the rating plate or take the side off and check value
common one is 7uF but could be 8 you would need to check
October 15, 2023 at 4:58 pm #488306The Equalizer
Just looked, its an 8.5uF
Regards
Simon
October 15, 2023 at 5:06 pm #488307electrofix
Moderatorthats a gen part only
https://shop.ukwhitegoods.co.uk/c00258619-8-5uf-capacitor
you could put an 8uF in to make it cheaper
https://shop.ukwhitegoods.co.uk/g873197as-washing-machine-tumble-dryer-dishwasher-8uf-capacitor
should work almost as well. well enough so you would not notice
October 15, 2023 at 8:33 pm #488308The Equalizer
ParticipantNuts!
Too late, I bought the Gen part.
Never mind, I’m happy to pay the extra just for the advice I’ve received.
I’ll know for next time.;)
Regards & Thanks
Simon
October 20, 2023 at 12:09 pm #488309The Equalizer
ParticipantGents
A quick question
I can see no markings on the Capacitor, so how can I tell which connector goes on which? Or doesn’t it matter.
Simon
October 20, 2023 at 12:57 pm #488310The Equalizer
ParticipantNo Worries
Sorted it via youtube. In the sense that no video on YT mentions anything about which way around the wires connect, so I assumed that it doesn’t matter.
All put back together and working fine…… until next time.So thanks Dave, I am once again very grateful for your help.
October 20, 2023 at 2:52 pm #488311The Equalizer
ParticipantJust noticed that there is a little damp patch on the floor under the Tumble Dryer.
Water is collecting in the water Tank, but not a huge amount.What might that be?
