Hotpoint CDN7000P (UK) Tumble Dryer intermittently spinning
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint CDN7000P (UK) Tumble Dryer intermittently spinning
Viewing 15 posts - 1 through 15 (of 28 total)
  • #102314
    The Equalizer
    Hey Y’all
    My old Hotpoint CDN7000P(UK)
    Serial 505126563
    Thanks to you kind folk on this forum, I have replaced the Belt in the last year & the Pulley & Gasket around the front of the drum.
    Anyhow, today it decided to stop spinning. Its heating ok, and I noticed that with no load or very little, it will spin but literally only with 5 pairs of socks, that’s about it anymore, and it stops spinning, but makes a humming sound.
    So the belt is intact, no burning rubber smell.
    The pump is ok I think, I can hear it gurgling away.
    So I just wondered if you could once again point me in the right direction of what might be going on, or where to look?
    Thanks once again
    Simon
    #488298
    The Equalizer
    One more thing.
    Even with nothing in the dryer as the drum turns there is a slight thudding, as you would hear maybe if there was a full load and the load is falling side to side as the drum turns, but there is no load!
    #488299
    The Equalizer
    Sorry Can a moderator please amend the Topic title it should read [h=2]Hotpoint CDN7000P (UK) Tumble Dryer intermittently spinning[/h]
    I have a sticky no.7 key, sometimes it doesn’t work.
    Simon
    #488300
    common fault for no drum turn is the capacitor
    it normally starts with light loads but need a push to get a heavier load moving
    The Equalizer
    Thanks Dave
    Its stopped turning altogether at the mo, it is making a sort of buzzing crackling noise.
    Still possibly capacitor?
    If so, where is the capacitor situated, and is it replaceable?
    Simon
    #488302
    The Equalizer
    Yeah, its started moving now.
    Very puzzling?
    #488303
    cap is replaceable and sited next to the motor
    The Equalizer
    I’ll head over to the online UKW shop
    See if they have a capacitor.
    Thanks for your advice Dave
    #488305
    there are different values depending on motor fitted
    you can either let us have the complete set of numbers off the rating plate or take the side off and check value
    common one is 7uF but could be 8 you would need to check
    https://shop.ukwhitegoods.co.uk/wash…-7uf-capacitor
    #488306
    The Equalizer
    Thanks Dave
    Just looked, its an 8.5uF
    Regards
    Simon
    #488307
    thats a gen part only
    https://shop.ukwhitegoods.co.uk/c00258619-8-5uf-capacitor
    you could put an 8uF in to make it cheaper
    https://shop.ukwhitegoods.co.uk/g873197as-washing-machine-tumble-dryer-dishwasher-8uf-capacitor
    should work almost as well. well enough so you would not notice
    The Equalizer
    Nuts!
    Too late, I bought the Gen part.
    Never mind, I’m happy to pay the extra just for the advice I’ve received.
    I’ll know for next time.;)
    Regards & Thanks
    Simon
    #488309
    The Equalizer
    Gents
    A quick question
    I can see no markings on the Capacitor, so how can I tell which connector goes on which? Or doesn’t it matter.
    Simon
    #488310
    The Equalizer
    No Worries
    Sorted it via youtube. In the sense that no video on YT mentions anything about which way around the wires connect, so I assumed that it doesn’t matter.
    All put back together and working fine…… until next time.
    So thanks Dave, I am once again very grateful for your help.
    #488311
    The Equalizer
    Just noticed that there is a little damp patch on the floor under the Tumble Dryer.
    Water is collecting in the water Tank, but not a huge amount.
    What might that be?
