Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint CDT 00
- This topic has 8 replies, 5 voices, and was last updated 15 years, 7 months ago by
A1TEC.
August 24, 2010 at 7:45 pm #56776
A1TEC
ParticipantHave a problem with this one, cleaned out condense pump a few weeks ago, found the usual lint and crap.
Customer called back to say no water in drawer and electric tripped.
Went back the other week and checked the pump, the pump ran o.k found water had been thrown onto element causing electric to trip.Could this pump be intermitantly faulty ❓
Any help appreciated.
John.
August 24, 2010 at 8:13 pm #328798helo_75
Participantno, its more likely the hole between the pump housing and the condenser is blocked… cured by poking something (like a tie wrap) through the hole,. bottom left hand side of the pump housing clearing the blockage
August 24, 2010 at 8:44 pm #328799A1TEC
ParticipantRe: Hotpoint CDT 00
Thanks helo, will have a look at that.
cheersJohn.
August 24, 2010 at 10:54 pm #328800trotter
Had one doing the same a while back….fitted new pump & it cured the fault. Am I right in thinking there was a new design pump for this one?
August 25, 2010 at 7:37 am #328801Martin
trotter wrote:Had one doing the same a while back….fitted new pump & it cured the fault. Am I right in thinking there was a new design pump for this one?
The early pump is now obsolete and replaced by pump kit (C00260640). On later models a new Float & pin kit where required and later still models have a shorter float to allow more water into the chamber. It is important therefore to note down the serial number of the machine in order to fit the correct combination of pump, float and in some cases water deflector too!
August 25, 2010 at 7:54 am #328802helo_75
Participantits blocked!
simple scenario.. if it wasnt blocked and the pump was faulty, the float would activate and the heater would switch off, light comes on, no more water cos of no heat.. quick repair
blocked drain hole = no float switch activation, cos theres no water there, heater stays on, water condenses, builds up, pours into fan chamber and sprays on heater
its common sense guys..
August 25, 2010 at 10:01 am #328803wilf
pump impellar is just a bit of rubber so you can hear the thing running but you have to look to see that its not physically broken. I was caught out on this just last week
wilf
ps I now keep the update pump kit only in stock and use only the pump if required the buying in price is the same pump only or kit
August 25, 2010 at 11:20 am #328804helo_75
Participantlike i said….
EVEN IF THE PUMP IMPELLOR WAS BROKEN – IF THE DRAIN HOLE WAS CLEAR THE FLOAT WOULD SWITCH THE HEATER OFF
shimples
August 25, 2010 at 5:27 pm #328805A1TEC
It was a drain hole blockage, just as helo said. 😉
cheersJohn.
