HOTPOINT CDT00P DRYER.
  • This topic has 12 replies, 6 voices, and was last updated 17 years ago by DRH.
  • #44475
    DRH
    THE PUMP RUNS ALL THE TIME.
    FLOAT SWITCH O/K
    NO BLOCKAGES.
    #281089
    Specialist01269
    Re: HOTPOINT CDT00P DRYER.
    Hi: Are there any error codes showing?
    Andy.
    #281090
    DRH
    NO CODES ALL WORKS FINE.
    POSS TIMER?
    #281091
    Specialist01269
    Just been thinking: Unless i am thinking of a different machine, the pump is supposed to run continually until the the water container is full. Then the float switch activates to turn off the pump & heater and turns on the empty water bottle LED on the front panel.
    Andy.
    #281092
    DRH
    LED LIGHT ON ALL TIME
    BUT THE WATER TANK IS EMPTY
    THE PUMP RUNS ALL THE TIME,FLOAT SWITCH TRIGERED OR NOT???????
    #281093
    helo_75
    the pump runs continually, even when the light is on, it just turns the heater off
    the microswitch is faulty
    #281094
    DRH
    I HAVE HEAT.
    #281095
    helo_75
    so whats the problem?
    #281096
    helo_75 wrote:so whats the problem?
    A sticking CAPS lock on his PC. 😉
    Netiquette. 🙂
    helo_75
    ok, just to clarify
    the pump runs continuously., its supposed to
    the float switch turns the light on, the heater off
    if you have the light and the heater on, the switch is faulty
    #281098
    DRH
    job done.one of them days
    thanks all.
    #281099
    pup
    DRH wrote:job done.one of them days
    thanks all.
    so what was it ? martin is dying to know 😆
    #281100
    pup wrote:so what was it ? martin is dying to know 😆
    Huh? 😕
