Hi guys just wanted to know if someone can give me an idea of the route i should take to troublshoot this dryer , owner said it wouldnt start earlier and now it wont heat , i had a look at the elements and i could find no continuity through them thanks k
what i’m saying is , will the elements heat even though the stats are blown ? surely the power still goes to the elements and they should heat , if the stats are blown the temp will not be regulated and they will keep heating , is this right ? or does the power go through one stat first if thats ok then it heats the element and power goes back out through the other stat which regulates the temperature ?thanks
