Hotpoint CDT40 flashing lights and stops mid cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint CDT40 flashing lights and stops mid cycle
  • #50336
    bouf111
    My dryer seems to have developed a couple of faults.
    First occasionally it stops mid cycle with on beep and the front panel lights are flashing.
    The second fault is that the dryer just stops mid cycle with no flashing lights etc? even though the desired time hasn’t elapsed.
    Can anyone help on this.
    thanks
    #304477
    helo_75
    the doors probably warped
    if you open the door, theres a pin at the 12 oclock position, and that operates the switch
    i bend the door a little so the pin is nearer the switch
    that normally does it
    #304478
    bouf111
    Re: Hotpoint CDT40 flashing lights and stops mid cycle
    thanks for the prompt response, I will have a look at that
