If you remove the fan cowling from the top of the fan..you can then get at the 2 bolts that hold the pulley on..remove the pulley, then you can fit the belt over the pulley and refit pulley in place..
Removing the fan cowling gives you the extra bit of space needed to remove the pulley..
