HOTPOINT CERAMIC HOB E6005
  • #15865
    barryfast
    Hi All help Hotpoint ceramic hob will not turn up or down mod e6005
    is it the keysboard part No c00109305 thanks Barryfast 🙄
    #166603
    Re: HOTPOINT CERAMIC HOB E6005
    I would agree with you on that but as the cost is prohibitive I would first check it wasn’t a contact fault between it and the glass causing the problem?
    Also someone may have cleaned the glass with a a furniture type spray which will interrupt good finger contact. So a good clean with a solvent based cleaner around the control panel area is advisable first 😉
