Hotpoint cond dryer SUTCD97B6KM(UK) jockey wheel
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint cond dryer SUTCD97B6KM(UK) jockey wheel
  • #99149
    Washdisher
    Jockey wheel disintegrating. Hotpoint describe the wheel as integral with the motor. Connect show the wheel separately but out of stock: they show an alternative which has a sealed ball bearing instead of the plain bronze bearing. Anyone confident this is an acceptable alternative, particularly given that the ball bearing is recessed within the wheel? Any help much appreciated
    #475180
    hotpoint have modified these pulleys. The later one has bearing but the shaft is a different size so it means a motor swap
    looks like its part no C00566573
    kaibart
    Aswo stock a replacement for the pulley that has the bracket you can remove bracket and use pulley pulley part number is C00297219
    #475182
    murv
    Or remove the pulley wheel from jockey arm C00165972
    Murv…
